Ranger 900 25 hr tranny fluid change
1 reading
9.2K views 12 replies 7 participants last post by  Etxmatt
Ok so I was changing my fluid and put in 1 quart of the agl and then. Not paying attention added 6to8 oz of the (demand drive fluid thats intended for the front diff) should I worry or should I go ahead an swap it out btw at 25 hrs the magegnetic drain plug had quite a bit of metal flakes on it ...stock bike and not very hard on it
#10 ·
its on the passanger side of the transmission, to the rear of the gear selector cable. its the black sensor with a wire plugged into it and only one bolt holding it in place. when the bolt is removed it just slips out, clean the filings off and reinstall it. put a little grease on the O-ring when you reinstall it.... this will save some check engine codes and makes for a good clean signal to the ECM. i started doing this and i have never got the speed sensor fault code as i use too(alot) as others have with the ranger. this sensor counts the teeth on the pinion gear and sends to ecm for speed and AWD input. if there is alot of trash on the sensor it will send in some cases corrupt information to the ecm inturn bad info and set off the light. it has worked for me but just wanted to share it with ya.
#7 ·
I changed mine as well today. Also had the grey sludge.
I was only able to get one quart in rear trans. I was expecting a little more.
Front Diff I was only able to get 180-190 ml. in. ????? The manual says 225 ml. I used a syringe to get it into the fill port which worked well.
As far as mixing fluids, I would ask Polaris but they are prob. going to tell you to re-due it. Let us know. Maybe the front diff has higher temp properties. That might be better oil.?.?.
