Fuel Pressure Tester
17K views 8 replies 5 participants last post by  ThaCuda
I have a 2013 Ranger XP 900 LE. Went to start it today and it cranked, but would not start. Battery is new. 12.7v before load test. 10.5v during load test. Next, I want to test fuel pressure. I have watched many videos. Some check pressure at fuel tank. Some test on fuel rail. Some test by just cycling the key. Some suggest you have to start the engine (problem for me right now). Can anyone recommend a fuel pressure test kit (make, model #, where to buy) that includes the fittings to fit my Ranger? If I need any special fittings, same questions (make, model, where to buy?) Thanks.
#2 · (Edited)
#4 ·
Nate, I have had this kit since it was $39;00 :) and I haven't found a Ranger that had a (key on) fuel pump that I couldn't adapt it to with what is included. Install that tee anywhere in the fuel line after the pump and last filter and you are good to go for the duration. Amazon.com: Actron CP7838 Professional Fuel Pressure Tester : Automotive
can u attach the tester at the end of the fuel rail by placing the tester T between the Damper Quick connect and the Damper itself?
#5 ·
